Interface => Interface til varme systemer => Stoker kontrol => Emne startet af: egon efter Jan 01, 2009, 14:08
I have Outtemperature website http://www.blackpoint.pri.ee/ilm/ (http://www.blackpoint.pri.ee/ilm/).
In StokerKontrol misc settings I have:
Outtemperature website: http://www.blackpoint.pri.ee/ilm
Temperature search string: Temperatuur:
But it's not working. What is wrong in my settings?
Hi Egon
The reason is that the degree sign is not written as a character in the html on the page you have provided. If you look at the html code for the page, you will see this line:
<td style="padding: 2px; border: 0px;background: #FFFFFF;font: 10px arial;">Temperatuur: -2.9 °C
So what you have to do is to insert "°C" without braces as Temperature unit in StokerKontrol instead of the "°C" string that is default, then it will work for you.
Regards Jens
Thank You. It's working now. :)
I changed the Outtemperature website to http://blackpoint.pri.ee/pillefyr
In settings I have:
Temperature search string: Outdoor temp.</td><td>
Temperature unit: °C
But again it's not working. What is wrong in my settings?
In settings I have:
The line you should look at behind the scenes is:
<td style="padding: 2px; border: 0px;background: #FFFFFF;font: 10px arial;">Temperatuur: 16.7 °C
From this you have to set,
You could write the above in lowercase, it does not matter in the newest version of StokerKontrol.
Best regards Jens
In settings I have:
Best regards Jens
Sorry my settings are:
Outtemperature website: http://blackpoint.pri.ee/pillefyr
I made an external.html in StokerKontrol /web folder and I am trying to get the Outdoor temp from http://blackpoint.pri.ee/pillefyr, but its not working.
Oh i see - you have to look at this line then:
<tr><td>Outdoor temperature</td><td>16.3</td></tr>
And it gives,
Temperature search string: temperature
Temperature unit: </td></tr>
Notice the unit is replaced by some html tags.
This should work, but i have not tried it.
Regards Jens
And it gives,
Regards Jens
No I want the outdoor temperature in Ouman EH-203 Measurements. Its in the same page down below.
You cant, but the new temperature module from the new StokerKontrol 1.78 which have not been released yet, can do it.
To upgrade to the new temperature module do this:
Shut down StokerKontrol.
Download this file:
http://www.stokerkontrol.dk/download/1.78/TemperatureParser.class
And copy it into (override existing file)
c:\programs\stokerkontrol\src\dk\stokersoft\stokerkontrol\inet
Start StokerKontrol.
Your settings should be:
°c
Outdoor temp.
Regards Jens
Just wanna say thanks for your thread... :-) my outside temp. is also working now because of your discussion :-)
www.chipper.dk/pillefyr (http://www.chipper.dk/pillefyr)
noticed a problem today witht he website, all new content added has no pictures or the pictures are not working
Please send a link to your webpage, and provide information about your burner and StokerKontrol version.
Regards Jens
thank you for your advice it seems to have sorted itself now.
