Forfatter Emne: Nogle der kender udvidelsesprintet ok godt?  (Læst 1622 gange)
Offline beatrixmartin
« Dato: Jun 13, 2023, 02:46 »
How to lengthen the lifespan of vacuum cleaners
How long has it been since you last emptied the dust bag of your vacuum cleaner? Are you sure there isn’t dirt clogged inside the hose and filters? Trust me, even top rated vacuum cleaners need constant care and maintenance because, like anything else (humans included), vacuum cleaners need some upkeep.
To make sure that you aren’t throwing your money out the window, we have compiled a list of things to do to keep your vacuum cleaners good as new and going for a long time. Some of the tips are natural-- of course you need to empty the dust bags and check for clogs-- but it isn’t that simple. At least not for busy people.
Useful Reference: Best Vacuum Cleaners Reviews
  • Inspect the belt
The belt is something that not all users are familiar with. It is not as obvious a part like the handle or the roll, but it is no less important.
Belts are the frames around your brush roll that keeps it in place. Without a proper-working belt, your roll can easily fall out from its position or doesn’t spin correctly. Problems with the belt are anywhere from a fraying belt to a completely broken belt. A fraying belt means that it is not tight and secure enough to lock the brush roll solidly in place. When this happens, simply take out the roll then re-secure the belt with your hands. The same solution applies to when the belt slides out of place. It shouldn’t be a difficult task and, depending on the brand, it should be listed in the manual. Top vacuum cleaner brands like Shark have very detailed manuals that guide you anywhere from usage to maintenance.
When the belt is broken or has damages on it, it’s time to replace it. You can find such accessories in home appliances stores or through online platforms like Amazon. Regularly, it is recommended to have belts replaced every six months but of course, this figure is tentative, depending on usage. If you vacuum often, perhaps up this number by a month or two, so replace it every, say, 4 to 5 months. But if you just hate house chores, you probably do not need this measure until your vacuum is 6 months old.
  • Clean the filter
Modern, best vacuum cleaner brands have a complex system of filters that make sure the best  cleaning experience and the highest air quality. Depending on the brand and the model, this system normally consists of a pre-motor filter, a post-motor filter, and a HEPA filter.
According to vacuum cleaner experts, the pre and post motor filter needs to be washed every 2 to 3 months, depending on the regularity of the usage. When you do so, remember to wash them by hand as the materials of these filters (usually cotton) are delicate and can be easily damaged. Once you’re done washing, let them dry under natural sunlight as driers can easily tear them apart.
For the HEPA filter, it is best to have it cleaned every 6 months. This is to make sure that no dust is trapped inside the mesh that is supposed to filter harmful allergens from re-entering the air. The HEPA filter is said to up the air quality in your home, protecting the health of those with lung problems and allergies by eliminating pollutants and invisible hair from the atmosphere. An old and neglected HEPA filter, however, can easily downgrade air quality by releasing even more dirt into the air.
Important Site: The Unexpected Choice: Top Rated Vacuum Cleaners Revealed!
There are a lot of ways to preserve the longevity of your vacuum. Be it canister, corded or cordless vacuum cleaners, they cannot survive without maintenance. We hope that this guide has been helpful. Good luck!
« Senest Redigeret: Nov 10, 2023, 05:02 af beatrixmartin »
