Pillefyr => Boink, Scotte, Woody, Biocomfort, RTB => Emne startet af: egon efter Sep 17, 2009, 20:38
Titel: Woody problem
Indlæg af: egon efter Sep 17, 2009, 20:38
I have problem with Woody. Its restarting continuously. First it goes to IGNITION 1 and feeds the pellets then feeding stops and Woody goes to restart showing WOODY 4.14 then it shows CHECKSUM-ERROR RAM:0 PROM1:1 PROM2:0 and then CHECKING and IGNITION 1 etc.
What is wrong with my Woody?
Here is video what it does http://www.youtube.com/watch?v=D6g_UNQ8p7k (http://www.youtube.com/watch?v=D6g_UNQ8p7k)
Titel: Sv: Woody problem
Indlæg af: BoinkUser efter Sep 18, 2009, 15:24
Hi Egon
According to this thread:
http://www.stokerforum.dk/index.php?topic=708.0
Which almost describes the same problem as you encounter, you need a new program chip for your burner. As you get a checksum error in prom1 this also sounds like the right solution.
Regards Jens
Indlæg af: egon efter Sep 19, 2009, 14:06
Hi Egon
Regards Jens
Yes I think I need a new chip, because now when I power on the Woody the display is blank, only the display back light comes on.
Indlæg af: BoinkUser efter Sep 19, 2009, 21:19
A blank display may be one/more capacitors on the main board that are broken. They will "push up", and you can see it by eye if they are defect. But it can also be the chip and possible other things i am not aware of.
Regards Jens
Indlæg af: egon efter Sep 22, 2009, 07:46
Replaced the chip and the display is still blank. :( I did not see no "push up" capacitors on the main board. I guess the main board is faulty. Any ideas how to fix this?
Indlæg af: roofer efter Okt 03, 2009, 20:49
Buy an Oil Boiler.
NBE make Junk Products,
Ask people in Ireland who must take them out after spending thousands of Euro.
They do not support the customer or supply parts to the Dealers.
Køb en Olie kedel.
NBE gøre uønsket Products,
Spørge folk i Irland, der skal tage dem ud efter at have tilbragt tusindvis af euro.
De støtter ikke kunden eller levere reservedele til forhandlerne.
Indlæg af: Jannich efter Okt 04, 2009, 04:44
Buy an Oil Boiler.
Køb en Olie kedel.
I think you should calm down.
Peter from Ecoboilers doesn’t want to pay the price for the items
and blaming Green Energy for overcharging.
Green energy is our importers and Kedco is OPOP´s importer
So from one of those two,  it should be possible to get spare parts.
Have you tried to contact them directly ?
When we have importer, we cannot sell directly to Peter from Ecoboilers
I don’t know what happen between Ecoboiler and Green Energy,
 but it seems the don’t like each other.
You can e-mail directly, Jannich@nordjysk-bioenergi.dk
and get the name of a dealer from Scotland,
that are able to supply you with spare parts.
Regards Jannich
Indlæg af: Jannich efter Okt 04, 2009, 04:54
Buy an Oil Boiler.
Køb en Olie kedel.
john@greenenergytechnologyltd.com
Regards Jannich
