Forfatter Emne: Opdateret app v 1.175 til V7 opdateret i dag - virker ikke  (Læst 4839 gange)
Offline Toftebo
Nu var jeg lige så glad for den app, men jeg skulle nok ikke have opdateret til dagens version. Den går ned med det samme, og Android siger den er til besvær. Har prøvet at geninstallere, men ...
Andre der ser det samme ?
Arne
Offline 347Michael
    • Mit fyr
Sv: Opdateret app v 1.175 til V7 opdateret i dag - virker ikke
« Svar #1 Dato: Jan 11, 2021, 19:20 »
Samme her, samsung s9
Kedel: BS 1016. 2013
Brænder: 10 KW. 2014
VVB 110 L Metro
3 vejsventil
Keramisk eltænder
6,5 m 160mm isokærn
Offline Tysker
« Svar #2 Dato: Jan 12, 2021, 10:30 »
Same here, Realme X2 pro. I'm on SW 7.0967.
Offline Hemhems
  • Respekt optjent: +5/-0
« Svar #3 Dato: Jan 12, 2021, 10:38 »
Jeg bruger ikke app'en - online browser virker altid mere end fint..
Scotte 10kw - V7 - BS20 Kedel
Smedegaard Simflex 25/60
3 Vejs ventil - Vølund QMC100
Offline Tysker
« Svar #4 Dato: Jan 12, 2021, 11:28 »
That's not the point though. NBE provided an update to an app that worked perfectly fine, and now the (updated) app crashes. Should not happen. And of course it's easy to get the old version of the app back (although getting the indstillinger, such as screen settings, back is a manual process).
By the way (don't want to open another thread), as I said in my earlier post I'm on SW version 0967, i.e., I "upgraded" my v7controll to "app only" control and can't easily downgrade to NBS's new SW version that deals with the Y21 bug. Is it worth the effort to do the downgrade via SD card, or should I just continue to use v0967 with the year set to 2016 for now (so weekdays are at least right)? In other words, other than the Y21 bug being fixed, are there any other benefits of v0674 over v0967? Does anyone know if there are publicly accessible change logs for the various SW versions (I looked but could not find anything)?
Offline Hemhems
« Svar #5 Dato: Jan 12, 2021, 11:35 »
Yeah i do not disagree and nbe have had it's share of glitches with updates around new year.. But i think their trying their best to solve it and ppl reporting it here will surely help.. I just keep using the browser and didn't like the app..
« Senest Redigeret: Jan 12, 2021, 11:36 af Hemhems »
Offline kyhn
« Svar #6 Dato: Jan 12, 2021, 12:09 »
Samme her, virker ikke, nåede heldigvis ikke at opdatere på Tablet, men android telefon virker ikke længere  :'(
Offline kyhn
« Svar #7 Dato: Jan 12, 2021, 12:13 »
I desided to do it by SD Card, it worked fine and only took me 15min to get it done. I was running a version (think it was same as you) without possibillity for setting an output the air compressor, that I can do now, at least for me that was a great plus :)
Offline Hemhems
« Svar #8 Dato: Jan 12, 2021, 12:43 »
Updates with the changes tho missing 0674 update but thats only because of the newyear date crash.
https://www.nbe.dk/program-download-2/
Offline Tysker
« Svar #9 Dato: Jan 12, 2021, 12:43 »
Thanks Kyhn and Hemhems!
« Senest Redigeret: Jan 12, 2021, 12:44 af Tysker »
Offline Brian Nielsen
« Svar #10 Dato: Jan 12, 2021, 16:04 »
Jeg havde samme problem.
Jens har været hurtigt til at finde fejlen og har opdateret appen i dag.
Den køre nu helt fint uden at gå ned.
Så prøv at hente den.
« Senest Redigeret: Jan 12, 2021, 16:06 af Brian Nielsen »
Brian Nielsen
BS1016 V10 styring opdateret til tablet styring (installeret 2015)
Opvarmer 200m2 (2 plan) - Bruger ca 3,5 tons
Solfanger
Offline Toftebo
« Svar #11 Dato: Jan 12, 2021, 18:36 »
v 1.176 går ikke ned, men finder ikke mit fyr på Samsung tab s7+, som den gamle gjorde. Virker på Samsung tab s5e.
Arne
