Forfatter Emne: gammel kontrol (v.4?) ekstern skrue tilføres uden pause, change to v7  (Læst 7189 gange)
Offline Hemhems
  • Respekt optjent: +5/-0
I still have the original auger that came with burner, but it is too short to reach the silo (next room). If i cant find a solution, maybe i build a small secondary silo next to the furnace. The big one can fill that then. But that is more of a long term solution  :(
It is possible to modify the coil/spring with adding a core to it. The 60mm auger i have has a open center of 16mm and a electrical or metal tube can slide in and fill it up and your measured weight will go down a lot.. I had it in mine for a long while, but it made issues with the pellets i use now. But worked fine before tho..
« Senest Redigeret: Jan 26, 2021, 17:43 af Hemhems »
Scotte 10kw - V7 - BS20 Kedel
Smedegaard Simflex 25/60
3 Vejs ventil - Vølund QMC100
