Forfatter Emne: Ball bearing for auger Spiral for RTB 120-320 hopper 90°  (Læst 1678 gange)
Offline mpetre
I own a RTB 30 with a 320 hopper. Due to bad quality pellets, the ball bearing at the bottom of the hopper auger broke. The auger is no longer able to feed pellets to the burner. It is possible to order just the ball bearing assembly (repair kit) without the auger spiral (SKU 400975) or would someone know of a suitable replacement bearing?
Jeg ejer en RTB 30 med en 320 tragt. På grund af dårlig kvalitet piller gik kuglelejet i bunden af tragtsneglen i stykker. Sneglen er ikke længere i stand til at tilføre piller til brænderen. Det er muligt at bestille kun kuglelejesamlingen (reparationssæt) uden sneglspiralen (SKU 400975), eller er der nogen, der kender til et passende udskiftningsleje?
THanks/Tak!
Regards, Michael
30kW RTB, v7, 90deg auger
  • Respekt optjent: +168/-24
Sv: Ball bearing for auger Spiral for RTB 120-320 hopper 90°
« Svar #1 Dato: Aug 20, 2023, 16:39 »
Try to contract your local dealer, they have acces to alle spareparts.
You can try Hedestoker.dk
Most spare parts are universal, including bearings, which have a number on the bearing, and you can order based on that.
Buy only good quality woodpills, it pays off in the long run.  ;)
