Forfatter Emne: StokerKontrol 2.01 English beta released  (Læst 10545 gange)
« Dato: Apr 20, 2010, 20:29 »
Hi
If you got beta tester access, please download the new StokerKontrol 2.01 english version.
These are the changes since last version:
StokerKontrol 2.0
- Graphic system view with editor
- Email sending now uses Stokersoft server, and no SMTP server setup is needed
- Wireless ATC serial modems are now supported (together with chip 6.16+)
- Eventlog that tracks changes to the system is added.
- 24 hour overview added under graphs panel
- Advanced evenlog added for errorfinding/support
- Interconnection with SunKontrol 2.0 possible
- Website is updated dynamically without any page refresh
- Total consume is now compensated with the "pills pr 6. min" value
- Export to excel now supports the new fiels from chip 6.0
- It is possible to choose "Classic website view" which is the old style
- The FTP upload mechanism is more stable and able to restore itself
- Consumption pr. m2 can be calculated, if the m2 are specified
- The pump output is now set correctly
New in StokerKontrol 2.01
- Fixed so internet, woody and usb sensor is used for out temperature in the editor
- Added extra temperature (usb sensor) to the editor
- English language added
NB. This version is also in Danish but only downloadable from the English download section.
Regards Jens
Offline egon
    • egon.net.ee
Sv: StokerKontrol 2.01 English beta released
« Svar #1 Dato: Apr 21, 2010, 08:48 »
Thanks for English version.
How can I set the Magazine load (kg) its greyd out in setup?
« Svar #2 Dato: Apr 21, 2010, 09:07 »
Hi Egon
You need chip version 6.03 or higher for this to be enabled.
Regards Jens
Offline egon
    • egon.net.ee
« Svar #3 Dato: Apr 28, 2010, 12:54 »
One bug I found so far:
In webpage there is a link "Tryk her for uddybning af forbrug", it should be in English.
« Svar #4 Dato: Apr 28, 2010, 18:59 »
Hi Egon
Thanks, will fix that soon.
Regards Jens
Offline funami
« Svar #5 Dato: Aug 19, 2010, 07:00 »
It is possible to get somewhere EN version 2.0 for myself?  ??? I know it is officialy only in Ny. Or not?
Somebody here has even 3.0 beta in EN .... in section online systems
Thank you
« Senest Redigeret: Aug 19, 2010, 07:16 af funami »
« Svar #6 Dato: Aug 19, 2010, 10:09 »
Thank you
Hi Funami
Please send an email to info@stokerkontrol.dk and we will look at it.
Regards Jens
Offline funami
« Svar #7 Dato: Aug 19, 2010, 10:53 »
Yes i did it, thank you
