Forfatter Emne: back-draught?  (Læst 9748 gange)
Offline shun
back-draught?
« Dato: Feb 19, 2013, 14:44 »
Hi to all.
Please, express possible reasons relatively the situation that has occurred. I talk about the one Woody owner  from Krasnoyarsk  http://www.stokercloud.dk/dev/showgraph.php?mac=gech .
Irregular supply of pellets to the burner had been observed during a long term, that’s why the user has been experimenting with different pellets from various manufacturers and supplied to the hopper with small dose (for one/two days).
At some moment a smoke appeared from the boiler. Probably, the batch of test pellets ended. The smoke went from a lad coupled with corrugation of the burner. Everything was disconnected about hour after the smoke appearance (nobody home except for one worker). The burner was very hot and a part inside was melted. The photosensor and  part of motorprint were burned. The drop shaft sensor hadn’t worked and even a temperature on it dropped a little bit. In principle, the temperature had been shown quite correctly by the sensor before.
A few questions: Why the sensor drop shaft hadn’t worked to increase? What in general could happened (what are the reasons)?
ps. gear motor is failed.
« Senest Redigeret: Feb 19, 2013, 15:09 af shun »
Offline Martin Pedersen
  • Respekt optjent: +174/-137
Sv: back-draught?
« Svar #1 Dato: Feb 19, 2013, 15:51 »
Hi Shun
Is it possible the gear motor failed before it actually started burning back in the buffer chamber? If this is the case, the burner is unable to evacuate the chamber of pellets.
The pellets you poured onto the ground, were they in the chamber or on the burner grate... or both?
Solvarme 30 Rør, 300L
Offline shun
Sv: back-draught?
« Svar #2 Dato: Feb 19, 2013, 20:05 »
Thanks for the answer Michael
Yes, it could be,but anyway why the drop shaft sensor didn't react on the temperature increase?
I'll pass it to the user, cause in a present situation I address as a "imprecise transponder".
Sv: back-draught?
« Svar #3 Dato: Feb 19, 2013, 20:15 »
Are you sure it didn't?
Were the controller in an alarm state?
If the shaft sensor detects a overheated shaft it would stop the external auger.
Then it'll start running the internal auger and the fan to burn off all the material. But in your case I'm thinking that maybe the internal auger didn't work, and then it cant empty the chamber. Does this sound plausible?
Sv: back-draught?
« Svar #4 Dato: Feb 19, 2013, 20:36 »
I Agree with Martin. If the internel auger failes an other things is faling to there will be multi alarms going on so the user will not se that the sharft alarm has gone off to . If it diden`t there will have been more fire in the burner as the xternal auger will contiune to feed more pilles.
Offline shun
Sv: back-draught?
« Svar #5 Dato: Feb 19, 2013, 20:45 »
completely. and explains it all.
But. The graph shows that the drop shaft temperature did not grow, but fell.
:-[ oops, I don’t know.
will be passed again.
Offline shun
Sv: back-draught?
« Svar #6 Dato: Feb 19, 2013, 20:50 »
External auger was empty: pellets was over.
Sv: back-draught?
« Svar #7 Dato: Feb 19, 2013, 20:54 »
If you zoom in closely on the graph, you can see a recorded value of above 100 degrees on the shaft temperature at 15:22:43... and soon after that It probably burned off. Now the sensor probably just records a invalid value that flips the controller into alarm no matter what.
I'm also quite sure when the light sensor burns off it will register an invalid value and stop by that as well... so to me it seems very safe. It's just very expensive when the internal auger fails... unfortunatly :( But, if you compare it to some other pellet stoves, it's not that bad... we've seen some ekoheats do the same, and they destroy the controller and all electrical stuff as well...
Sv: back-draught?
« Svar #8 Dato: Feb 19, 2013, 20:55 »
heh, so it managed to burn itself up with the last pellets... that was unlucky :P
Offline shun
Sv: back-draught?
« Svar #9 Dato: Feb 19, 2013, 21:00 »
(eyes wide open): epic.
Offline shun
Sv: back-draught?
« Svar #10 Dato: Feb 19, 2013, 21:04 »
yeah. like a grim humor.
Offline shun
Sv: back-draught?
« Svar #11 Dato: Feb 20, 2013, 11:14 »
From the chamber only. The grate was empty.
Sv: back-draught?
« Svar #12 Dato: Feb 20, 2013, 11:37 »
I'd say it's likely that my theory is correct then. The incident started with the internal auger failing.
Offline shun
Sv: back-draught?
« Svar #13 Dato: Feb 21, 2013, 20:15 »
Thank you so much guys.
Local dealer confirms warranty and changes the entire burner. All this is also due to the discussion on your forum.
Is Control an integral part of the burner or an independent?
Sv: back-draught?
« Svar #14 Dato: Feb 21, 2013, 20:34 »
Good to hear. That's very good service.
The control unit is separate from the burner.
