Forfatter Emne: Pellmon  (Læst 18399 gange)
Offline lyrakken
Sv: Pellmon
« Svar #15 Dato: Dec 11, 2016, 15:40 »
Ærgeligt med stokercloud, og endnu mere ærgeligt at man har fjernet muligheden for at installere stokerkontrol.
Den fejl jeg får er under events: INFO -silolevel prediction error: Expecting value: line 1 collum 1 (char 0)
Sv: Pellmon
« Svar #16 Dato: Dec 11, 2016, 16:36 »
Mig bekendt har man da ikke fjernet muligheden for at bruge og installere Stokerkontrol, NBE har tværtimod gjort det muligt for Stokerkontrol at kommunikere med Stokercloud.  ;)
Offline motoz
  • Respekt optjent: +18/-0
Sv: Pellmon
« Svar #17 Dato: Dec 11, 2016, 17:32 »
Citér
I can not repeat that error, it means that the there was an error when trying to predict how long the silo contents will last according to your pellet consumption history.
Do you have a silo level graph looking something like this?
If the future prediction works there is a light gray area of the graph staring from 'now'  and going down to zero kg sometime in the future.
Offline motoz
Sv: Pellmon
« Svar #18 Dato: Dec 11, 2016, 17:59 »
Well, sometimes I need something to remind myself of my own reminders... That's actually an old bug I filed myself over a year ago to not forget about it... https://github.com/motoz/PellMon/issues/67
It occurs for a while around the time a new months begins (not exactly since pellmon counts 'months' as exactly 1/12 year to simplify the calculations). I haven't gotten around to fixing it yet, it's anyway temporary and only affects the silo level future prediction and causes some extra noise in the log.
Offline lyrakken
Sv: Pellmon
« Svar #19 Dato: Dec 11, 2016, 19:28 »
Det er ikke muligt at installere på raspberry pi, fordi de nødvendige filer er fjernet fra stokercloud siden.
Btw. Er det muligt at hente udetemperaturen fra nettet som det er i stokerkontrol?
Jeg synes nemlog ikke om at der skulle være 199 grader.
Offline kivi
  • Respekt optjent: +7/-0
Sv: Pellmon
« Svar #20 Dato: Dec 11, 2016, 19:52 »
Jeg ved ikke om pellmon kan hente temp. fra nettet, det må motoz svare på.
Men hvis ikke, kan du jo selv sætte en føler på, det har jeg gjort.
Ole
Offline kivi
Sv: Pellmon
« Svar #21 Dato: Dec 11, 2016, 19:57 »
Og Kenneth, du trænger til at få opdateret din signatur ^-^
Ole
Offline motoz
Sv: Pellmon
« Svar #22 Dato: Dec 11, 2016, 20:08 »
No, pellmon can't fetch outside temperature from the internet.I have a couple of onewire sensors to measure outdoors and indoor temps and a couple of others, they are cheap and very accurate. You can of course add a sensor directly to the controller, or you can remove the outside temp reading from the system image to avoid seeing the annoying 199 degrees.
Sv: Pellmon
« Svar #23 Dato: Dec 11, 2016, 20:42 »
Sørme osse da ^-^
Nå, jeg troede netop at Pellmon's styrke lå i at man kan lave hvad man vil  :) men det kræver naturligvis at man kan hvad man vil.  :D
Offline kivi
Sv: Pellmon
« Svar #24 Dato: Dec 12, 2016, 06:53 »
kenneth, hvorfor har du set dig så sur på et gratis stykke software, der hjælper os v6 brugere med at komme nemt og billigt online.
Stokerkontrol er mig bekendt ikke blevet opdateret de seneste 4-5 år.
Ole
Sv: Pellmon
« Svar #25 Dato: Dec 12, 2016, 09:59 »
Jeg har bestemt ikke set mig sur på noget som helst, jeg har bare misforstået nogle indlæg,  ;)
Jeg troede at det var open source, og at man kunne lege med det som man lyster, og i så fald er det jo programmørens kvalifikationer der afgør om man kan implementere data fra andre hjemmesider. Som tidligere hjemmeside konstruktør kan jeg da berette at det slet ikke er umuligt, det virker jo også i Stokerkontrol.
Det var ikke noger der ærgrede mig at Stokerkontrol ikke opdateres længere, det virker jo perfekt, og hvis der er noget jeg ser mig sur på så er det altså alle de forbandede opdateringer.
Og er Pellmon nu også et billigt alternativ til at komme online! Efter at NBE gjorde det muligt at Stokerkontrol kommunikerer med Stokercloud skal man jo ikke længere have server plads ude i skyen, jeg ved godt at der findes gratis host løsninger, men de er ofte fyldt med reklamer.
Jeg har også forstået at Pellmon kun monitorerer systemet, og at man ikke kan styre fyret derfra. Hvis det er rigtig forstået så er det jo helt sikkert et "minus" (for mig)
Det vigtigste er jo at du har et system der matcher dit behov, og din investerings villighed  :)
Offline kivi
Sv: Pellmon
« Svar #26 Dato: Dec 12, 2016, 10:19 »
Hehe det lød bare sådan Kenneth.
Pellmon er da open source, jeg har bare ikke nok forstand på programmering til at ændre ret meget.
Du kan styre næsten alle parametre på fyret fra Pellmon og jeg kan gøre det fra min ipad.
Hvis alternativet er at købe ny styring, så er en Raspberry en billig løsning, der tilmed ikke bruger meget strøm.
Alt i alt er jeg meget tilfreds med det setup.
Ole
Sv: Pellmon
« Svar #27 Dato: Dec 12, 2016, 10:22 »
Det er bare super, kunne du ikke smide et link i din profil ,så man kunne følge lidt med i hvad det er for noget fint noget  :D
Offline motoz
Sv: Pellmon
« Svar #28 Dato: Dec 12, 2016, 18:41 »
There you go, PellMon versin 0.7.0-beta4 with a new plugin Openweathermap that reads outside temperature from openweathermap.com
I thought it would be really quick to add, but there went two hours again...
https://github.com/motoz/PellMon/releases
And since that was apparently not clear to everyone; PellMon is free and open source, meaning that you can see the source code, modify it to suit your needs and even sell it if you like.
The openwheathermap plugin code for instance looks like this: https://github.com/motoz/PellMon/blob/develop/src/Pellmonsrv/plugins/openweathermap/__init__.py
Offline lyrakken
Sv: Pellmon
« Svar #29 Dato: Dec 12, 2016, 21:32 »
Har ikke prøvet det endnu, men damn det er god service...
Jeg går ud fra at det bare er at opdatere via deb package.
