Interface > Interface til varme systemer
integration med hass.io
zune:
Det kunne være super fedt hvis styringen kunne ekponere "sensore" og "switches" ud mod eks, en mqtt eller noget i den dur således at man kunne trække dem ind i hass.io eller endnu bedre lavede en rigtig integration med systemet :D
motoz:
It can...
John Doe:
--- Citat fra: motoz efter Maj 13, 2020, 17:24 ---It can...
--- Afslutning på citat ---
Motoz could you be helpful in telling us how to? And is it possible without pellmon?
motoz:
Sorry about that... No, the controller can't do it directly. It speaks two protocols (as far as I know of), the homegrown UDP based (server) and http (client, for stokercloud). The only ready made solution to bridge from the UDP protocol to MQTT that I know of is pellmon + pellmonmqtt, but there could be others. This combination gives you access to all measurement values and all settings. The openhab binding + openhab + somethingmqtt might work also, I don't know. There has been very little interest in pellmonmqtt so I never made an installer for it. It's just one python script though, so there isn't much to install. You have to make it start on boot however.
John Doe:
--- Citat fra: motoz efter Okt 22, 2020, 16:54 ---Sorry about that... No, the controller can't do it directly. It speaks two protocols (as far as I know of), the homegrown UDP based (server) and http (client, for stokercloud). The only ready made solution to bridge from the UDP protocol to MQTT that I know of is pellmon + pellmonmqtt, but there could be others. This combination gives you access to all measurement values and all settings. The openhab binding + openhab + somethingmqtt might work also, I don't know. There has been very little interest in pellmonmqtt so I never made an installer for it. It's just one python script though, so there isn't much to install. You have to make it start on boot however.
But Pellmon is to be installed on another RPi? I suppose that you can't run it alongside with Home Assistant.
Navigering
[0] Emneindeks
[#] Næste side
Skift til fuld version
