Forfatter Emne: How long between "compressor charges"?  (Læst 4518 gange)
Offline Tysker
« Dato: Mar 10, 2021, 17:10 »
I've got approx. 7 hours between "compressor charges" (RTB 10) when no compressorrens is happening - in other words, the system loses enough pressure in 7 hours that the compressor kicks in and builds the pressure back up.
I have no idea if this is good, tolerable, or bad.
What are your "times between charges"?
MvH
Karsten
383CI
Sv: How long between "compressor charges"?
« Svar #1 Dato: Mar 10, 2021, 17:30 »
50Kg. piller, altså 2-3 dage. Aldrig en slag eller uforbrændt pille i asken. Ikke en efter 2,5 tons piller.
Offline Hemhems
  • Respekt optjent: +5/-0
« Svar #2 Dato: Mar 11, 2021, 18:54 »
Hello
Something seems to be leaking somewhere.. it's not normal that it would drop in pressure if not used.. My external small 6 liter has no pressure leak and keeps the charge atleast until the next pressure clean.. The model provided with nbe is not that good and could leak from the seals over time. The solenoid valve could also be a failure point as fittings could have a leak or the solenoid itself.. Try to check the compressor itself without it being connected to see if it's the culprit or af it..
« Senest Redigeret: Mar 12, 2021, 00:06 af Hemhems »
Scotte 10kw - V7 - BS20 Kedel
Smedegaard Simflex 25/60
3 Vejs ventil - Vølund QMC100
383CI
« Svar #3 Dato: Mar 12, 2021, 06:42 »
Oooh, jeg svarede på noget forkert.
De små kompressorer der følger med fyret er pisse utætte. Den er ikke længere.
Min holder slet ikke 7 timer, heller ikke uden slange monteret, så det er selve kompressoren der er dårlig, eller rettere, sikkert fin nok til 380kr. I Kina.
Enten skal du lade styringen starte og stoppe den, eller skifte den ud med en anden.
Offline Tysker
« Svar #4 Dato: Mar 13, 2021, 12:56 »
Thanks very much to both of you.
Would one of these kompressors do the job? Güde 50136 or Cevik Pro24silenc (sorry, can't post links)
@383CI: I can monitor compressor pressure (using T7) with my styring (v7), but I can't connect/control the kompressor itself (I think).
« Senest Redigeret: Mar 13, 2021, 13:21 af Tysker »
383CI
« Svar #5 Dato: Mar 13, 2021, 16:33 »
Alle kompressor kan gøre gøre det. Rensningen bruger ingen luft. Jeg tænker den der fælger med standard er valgt udfra et synspunkt om den skal være billig (i indkøb) og ikke sige ret meget.
Begge dele er ramt knivskarpt. Den er både billig og lydsvag, men jo så heller ikke tæt.
Hvilke der evt. er det ved jeg ikke. Jeg har en 5hk også, den taber slet ikke tryk over flere dage, men den er for voldsomt at have igang for det.
Du kan vælge kompressor udgang "udvidet setup ON" -> Kedel -> Rensning -> Kompressor rens -> Kompressor udgang.
Men pas på. Hvis du køre kompressoren over printet, og den sætter sig, brænder der et eller andet af meget hurtigt.
Om det er printet eller kompressoren ved jeg ikke.
