Forfatter Emne: P-gain 0.50 I-gain 0.20 D-gain 0.00  (Læst 2920 gange)
Offline VGY-europe
« Dato: Mar 08, 2022, 23:28 »
Hello, maybe some one could explain this parameter?
Sv: P-gain 0.50 I-gain 0.20 D-gain 0.00
« Svar #1 Dato: Mar 09, 2022, 08:12 »
Yep, it's the controller that determines the percentage performance of the pellet stove.
P is the distance from the actual temperature to the desired temperature, I is an addition over time, and D is an opposite force, D should not be used for a pellet stove, so it should just remain 0.
Without having graphs to look at it is difficult to adjust the controller and I recommend P 2 and I 0.2 D 0
You can watch many videos about PID controllers on Youtube.
