Forfatter Emne: ftp uploading problem  (Læst 7442 gange)
Offline egon
    • egon.net.ee
« Dato: Jan 06, 2011, 10:33 »
I reinstalled my pc and stokerkontrol and now I cant get the ftp uploading to work. Are there any log files generated by stokerkontrol where I can see what is the problem with ftp?
Sv: ftp uploading problem
« Svar #1 Dato: Jan 06, 2011, 11:09 »
Hi Egon
You did not write which version of StokerKontrol you are using, but if it is one of the newer versions, you can activate "Advanced logging", then you can view the log for "today" and it will tell you what is wrong with your ftp - however it is not very easy to read, but you might search for "ftp".
Regards Jens
Offline egon
    • egon.net.ee
« Svar #2 Dato: Jan 07, 2011, 08:36 »
Got it working and found the cause. If you dont specify a FTP folder in stokerkontrol options then you get error in log:
com.enterprisedt.net.ftp.FTPException: 550 \: No such file or directory.
It is strange because it worked before I reinstalled my pc. So if I want to upload to the root folder of the ftp server, I cant.
Is it a bug? I am using stokerkontrol v3.12.
