Forfatter Emne: New chip from NBE  (Læst 6250 gange)
Offline egon
    • egon.net.ee
New chip from NBE
« Dato: Nov 07, 2011, 11:45 »
I had a pleasant surprise in my mailbox today, a new chip from NBE. I don't know why I got this gift, but thank you very much NBE! :)
My current chip is <4.16 and the new one is 4.99F.
Now before I swap my chip to new one, can somebody tell me what new features I can expect form the new chip?
And are there any things I have to do before or after I install this new chip?
egon
Sv: New chip from NBE
« Svar #1 Dato: Nov 07, 2011, 12:29 »
Hi Egon,
v4.99 is the last version in the v4.xx series and have some improvement in different areas.
However one of the most important improvements is the change in the oxygen-regulation.
In earlier versions the oxygen regulation was linked only to adjust the dosing of pellets, but from v4.99 it is linked both to adjustment of the blower and the dosing of pellets.
This improvement has given a much faster responce to changes in the process, fast responce in the air-flow and a slow constantly adjustment of the dosing of pellets.
Before changing the chip, remember to save your parameters/setup, either by writing them down or save via stokerkontrol.
egon
« Senest Redigeret: Nov 07, 2011, 12:30 af MHES »
Offline Jannich
  • Respekt optjent: +41/-5
    • NBE
« Svar #2 Dato: Nov 07, 2011, 12:29 »
egon
Hi Egon
We appreciate the good work on the android Apps
On 4.99F there are more setting for ignition, and an more slow PID regulation.
Regards Jannich
Pillefyr:
RTB 10kW
Solvarme:
Solcelle system:
Installeret aug. 2012
Offline egon
    • egon.net.ee
« Svar #3 Dato: Nov 07, 2011, 12:57 »
Hi Michael,
Thank you for the information and advice.
Hi Egon,
egon
Offline egon
    • egon.net.ee
« Svar #4 Dato: Nov 07, 2011, 13:03 »
egon
Hi Egon
Regards Jannich
Thank you for the chip again!
egon
p.s. Where I can set the language of this forum to English? Google translate is not so comfortable to use.
Offline Jannich
    • NBE
« Svar #5 Dato: Nov 07, 2011, 13:49 »
egon
Hi Egon
Regards Jannich
egon
Done deal  O0
Pillefyr:
RTB 10kW
Solvarme:
Solcelle system:
