Forfatter Emne: back-draught?  (Læst 13364 gange)
Offline shun
Sv: back-draught?
« Svar #15 Dato: Feb 21, 2013, 20:40 »
the next question (from me this time).
 a strange irregular noise  appears from the burner: semi-creak, semi-knock on metal.
what is it?
MartinPedersen
Sv: back-draught?
« Svar #16 Dato: Feb 21, 2013, 20:44 »
Could it be the cover over the burner resonating?
The way the fan speed is regulated is by pulsing 230v to the fan, and that makes a slight "tuk-tuk" sound, and that sometime plants itself in the cover over the burner.
Offline shun
Sv: back-draught?
« Svar #17 Dato: Feb 21, 2013, 21:12 »
... makes a slight "tuk-tuk" sound...
can be heard through the solid wall aerocrete 30cm.
MartinPedersen
Sv: back-draught?
« Svar #18 Dato: Feb 21, 2013, 21:16 »
Could be the internal auger cutting pellets in half. That sounds like crushing and then a small knock... it's very normal... especially if the pellets are very hard pressed.
Offline shun
Sv: back-draught?
« Svar #19 Dato: Feb 21, 2013, 21:23 »
Could be the internal auger cutting pellets in half. ...
yeah, exactly!
thank you very much Martin.
