Forfatter Emne: Hot water preparation by using brazed heat exchangers  (Læst 11184 gange)
Offline rekuper
Hello,
I am going to prepare hot water by using heater core by OPOP biocomfort16. Due to the fact I already have electric hot-water boiler I am going to buy the compact brazed heat exchangers to avoid the purchase any buffer tanks.
(http://www.reflex.de/reflex/html/index.php?lang=2&tp=23&link=14_3&arrow=blau&loc=Heat%20exchanger%20systems&loc2=reflex%20'longtherm'%20-%20compact%20brazed%20heat%20exchangers).
Does anybody some experiences with instalations - scheme connection?
Kind regards
Jir
i
Offline Jannich
  • Respekt optjent: +41/-5
    • NBE
Sv: Hot water preparation by using brazed heat exchangers
« Svar #1 Dato: Jan 11, 2008, 06:16 »
Normally requires a brazed heat exchangers some buffer,
when you open for the hot water , you use lot of energy ,
that energy must come from the pellets burner and boiler,
but the boiler contents only a few litres of hot water,
so you will empty you storage of energy fast.
The boiler temperature will drop, before the burner has adjusted to up the maximum output.
So if you going to use lot of hot water for long time ,
I will suggest a hot water tank on 200-300 litre.
Regards Jannich
Pillefyr:
RTB 10kW
Solvarme:
Solcelle system:
Installeret aug. 2012
Offline rekuper
« Svar #2 Dato: Jan 11, 2008, 08:36 »
That is truth. That´s why I have already the electric hot-water boiler (200 l) so I do not need any second one. And one more thing - I can use brazed heat exchanger for sun energy in summer.
I found some connection examples on web sites from reflex manufacturer.
I am going to try it and then publish in this forum. Would it be possible?
Regards
Jiri
