Forfatter Emne: Outtemperature website problem  (Læst 14949 gange)
Offline egon
    • egon.net.ee
« Dato: Jan 01, 2009, 14:08 »
I have Outtemperature website http://www.blackpoint.pri.ee/ilm/.
In StokerKontrol misc settings I have:
Outtemperature website: http://www.blackpoint.pri.ee/ilm
Temperature search string: Temperatuur:
But it's not working. What is wrong in my settings?
Offline BoinkUser
  • Respekt optjent: +83/-4
Sv: Outtemperature website problem
« Svar #1 Dato: Jan 01, 2009, 14:37 »
Hi Egon
The reason is that the degree sign is not written as a character in the html on the page you have provided. If you look at the html code for the page, you will see this line:
<td style="padding: 2px; border: 0px;background: #FFFFFF;font: 10px arial;">Temperatuur: -2.9 &deg;C
So what you have to do is to insert "&deg;C" without braces as Temperature unit in StokerKontrol instead of the "°C" string that is default, then it will work for you.
Regards Jens
Offline egon
    • egon.net.ee
« Svar #2 Dato: Jan 01, 2009, 18:42 »
Thank You. It's working now.  :)
Offline egon
    • egon.net.ee
« Svar #3 Dato: Sep 10, 2009, 15:42 »
I changed the Outtemperature website to http://blackpoint.pri.ee/pillefyr
In settings I have:
Temperature search string: Outdoor temp.</td><td>
Temperature unit: &deg;C
But again it's not working. What is wrong in my settings?
Offline BoinkUser
« Svar #4 Dato: Sep 10, 2009, 15:48 »
In settings I have:
The line you should look at behind the scenes is:
<td style="padding: 2px; border: 0px;background: #FFFFFF;font: 10px arial;">Temperatuur: 16.7 &deg;C
From this you have to set,
You could write the above in lowercase, it does not matter in the newest version of StokerKontrol.
Best regards Jens
Offline egon
    • egon.net.ee
« Svar #5 Dato: Sep 11, 2009, 07:06 »
In settings I have:
Best regards Jens
Sorry my settings are:
Outtemperature website: http://blackpoint.pri.ee/pillefyr
I made an external.html in StokerKontrol /web folder and I am trying to get the Outdoor temp from http://blackpoint.pri.ee/pillefyr, but its not working.
Offline BoinkUser
« Svar #6 Dato: Sep 12, 2009, 10:12 »
Oh i see - you have to look at this line then:
<tr><td>Outdoor  temperature</td><td>16.3</td></tr>
And it gives,
Temperature search string: temperature
Temperature unit: </td></tr>
Notice the unit is replaced by some html tags.
This should work, but i have not tried it.
Regards Jens
Offline egon
    • egon.net.ee
« Svar #7 Dato: Sep 13, 2009, 19:17 »
And it gives,
Regards Jens
No I want the outdoor temperature in Ouman EH-203 Measurements. Its in the same page down below.
Offline BoinkUser
« Svar #8 Dato: Sep 14, 2009, 17:15 »
You cant, but the new temperature module from the new StokerKontrol 1.78 which have not been released yet, can do it.
To upgrade to the new temperature module do this:
Shut down StokerKontrol.
Download this file:
http://www.stokerkontrol.dk/download/1.78/TemperatureParser.class
And copy it into (override existing file)
c:\programs\stokerkontrol\src\dk\stokersoft\stokerkontrol\inet
Start StokerKontrol.
Your settings should be:
&deg;c
Outdoor temp.
Regards Jens
Offline Chipmik
« Svar #9 Dato: Sep 29, 2009, 11:13 »
Just wanna say thanks for your thread... :-) my outside temp. is also working now because of your discussion :-)
www.chipper.dk/pillefyr
Offline BoinkUser
« Svar #10 Dato: Nov 11, 2009, 18:08 »
noticed a problem today witht he website, all new content added has no pictures or the pictures are not working
Please send a link to your webpage, and provide information about your burner and StokerKontrol version.
Regards Jens
Offline Absemia09
    • mail order wives
« Svar #11 Dato: Nov 23, 2009, 15:38 »
thank you for your advice it seems to have sorted itself now.
