Forfatter Emne: Fan speed  (Læst 3544 gange)
Offline fabjedi
  • Respekt optjent: +0/-1
    • Rtb
Fan speed
« Dato: Mar 18, 2019, 17:27 »
Hello
The fan's cleaning speed does not often appear on the graphs .... Is this normal? Normally it should appear every 10 minutes ...
Sv: Fan speed
« Svar #1 Dato: Mar 18, 2019, 18:52 »
Hello
It is not always visible on the graph, but you can hear it if you stand by the boiler.  :)
Offline fabjedi
    • Rtb
Sv: Fan speed
« Svar #2 Dato: Mar 18, 2019, 18:58 »
Yes I know that, but I am anxious :-)
Why does not this appear on the chart? One may wonder if the cleaning works properly :-)
Sv: Fan speed
« Svar #3 Dato: Mar 19, 2019, 09:23 »
If you scroll the graph you kan se the time, on each point of the graph. You will discover that they have a 30-32 seconds interval between each point.
As a blower clean takes 2-5 seconds, depending on settings, it will only appers sporadic on the graph.
« Senest Redigeret: Mar 19, 2019, 09:25 af Hjemme teori »
Offline fabjedi
    • Rtb
Sv: Fan speed
« Svar #4 Dato: Mar 19, 2019, 17:15 »
Nice explanation
Thanks
